05-19-2019 09:20
05-19-2019 09:20
Hi.
I love my new Versa Lite! But I just noticed that the white outline on the zero numerals on the clock
has a break on the far right side(there is a blank black section, the white outline has a gap). Was it designed like this, do I have a faulty watch face, or is this a programming display flaw that needs to be fixed?
Thank you.
Best Answer05-19-2019 10:02
05-19-2019 10:02
That might depend on which clock face you are using. I just looked at the Fitbit clock faces on the phone app, and notice the 'Trace' clock face does have such a gap on the right side of the 0, so I would guess that is just the way it was set up, but not a flaw in your Versa. If it bothers you, there are hundreds of other clock faces you can try.
Best Answer05-19-2019 10:06
05-19-2019 10:06
Thank you!
