verse lite I’m having trouble with the battery it seems like it has to be charged every day I wanted to know if that was normal the unit is only two months old
Best Answer@MarieMarzano No, it should not drain that fast. Have you installed any 3rd party clockfaces or apps? If yes, please uninstall them. Some of them may really drain the battery. Also, please reboot the tracker several times as described here.
