08-22-2018 21:14
08-22-2018 21:14
Over all I like Fitbit. I used Fitbit Charge and later on switch to fit bit Charge 2.
When Fitbit release GPS enabled (or so they advertise) and water proof Fitbit I was intrigued.
After some consideration I decided to buy it (got it directly form fitbit, sorry amazon)
It looks great, slightly over complicated design but fine I can get used to it.
Then I actually started using it ...
In the evenings I run a 2.1 mile loop, today I decided to use just versa (no cellphone since I have GPS on the device), for some reason my 2 mile loop today got shortened to 1.5. My pace went form 9 min/mile to 12 min/mile. (as the total time per loop remained about 17.5 mins) WTF is this?
Now I also enjoyed the alarm on my charge 2, it was simple great and quite. Can some one explain why did you have to remove the interface to set alarms form the App? Was it killing you? Yes it was hard to find, but did you had to remove it from the app entirely, it was more convent to set it through the app!!!
Also when I tried submitting feedback on Amazon, I was not allowed to 😞 apparently seller blocks feedback ...
Best Answer08-23-2018 01:30 - edited 08-23-2018 01:31
Hello @Kapitoshka
you can adjust your stride to tailor it to a known distance.
Also, I find the alarms really simple to set up and I am using all 8 of the, on a daily basis.
Here is the user guide:
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
