When I get a incoming call does the watch habe volume on it so I can hear it thank you
Best AnswerHi @Debbyduck12345 and welcome to the forums. When a Versa receives notice of an incoming phone call, it will vibrate. You can adjust the vibration on your Versa by swiping left from the clock face until you see Settings. Tap it and swipe to Vibrations, where your choices are Normal and Strong.
When a notification for a call comes in, and you tap the green icon to answer, it is the iPhone that will actually answer the call so if the volume is too low, you should adjust the volume there.
