01-30-2020 11:34
01-30-2020 11:34
My Versa last synced at 2:14 yesterday afternoon. Had not changed any settings and now will not find my network or sync. Versa says “WiFi off” in IP address on About screen. Have tried recommendations to place on charger and use app for finding and connecting to WiFi. App will not find network, nor accept it when entered manually. Also have shutdown and restarted Versa. What next?
01-30-2020 12:58
01-30-2020 12:58
Versa wifi is not used in normal sync. Sync uses bluetooth between Versa and phone, and phone's wifi to and from main fitbit database.
Versa wifi is used I think for loading music and firmware updates, though not absolutely sure on that.
One thing you didn't mention trying is turning phone off and on, or at least turning phone's bluetooth off and back on, assuming you are using phone app, which I don't think you mentioned.
01-30-2020 13:23
01-30-2020 13:23
Won't sync. Updated today. Rebooted devise, login. Nothing works.
01-30-2020 13:25
01-30-2020 13:25
I did all of those things. Still won't work. Last sync yesterday @Noon.
01-30-2020 14:21
01-30-2020 14:21
01-30-2020 15:36
01-30-2020 15:36
You hadn't mentioned before that you are connected to 2 sync devices. Leave bluetooth off on one device while trying to sync with the other.
01-31-2020 07:14
01-31-2020 07:14
Problem apparently remedied with waiting. Nothing I did seemed to make a difference, but last night I could sync from both iPhone and iPad. Thanks for the suggestions.
01-31-2020 07:26
01-31-2020 07:26
That is often the solution. Too often people keep thinking they have to take some actions because a sync didn't work, without realizing the solution is often patience.
01-31-2020 13:53
01-31-2020 13:53
Mine will still not sync. Last sync weds. It tries to sync, goes about half an inch and stops.
