06-04-2020 14:37
06-04-2020 14:37
I've entered a credit card in wallet. To check to see if it was added i entered my pin code. The wallet is now unlocked. How do i lock it so that the next time i usde wallet a pin is required?
06-04-2020 16:08
06-04-2020 16:08
I believe it automatically relocks when you close the pay app. It should ask for the PIN each time you open the app.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
Best Answer06-04-2020 18:00
06-04-2020 18:00
@wtksk8r , according to the manual it will stay unlock for 24 hours or until the watch has detected to have been removed from the arm..
Therefore while the tracker is unlocked only the wearer has access to Fitbit pay.
I noticed that as soon as I removed the tracker i had to re-enter the pin
