My Versa watch face has an area where it’s supposed to give me the local weather temperature, but all it continues to say is “fetching”. I’ve tried restarting and rebooting with no luck, plus I’ve had this issue with other face apps. Any ideas on how to correct this?
Best Answer@Doug44 More than likely the problem you have with the weather on a clock face is related to the Yahoo Weather API being retired by Yahoo. Clock Face developers need to update their programming for their faces to the current free Yahoo weather API. You can reach out to the face developer (listed at the bottom of the face description) and ask about update status or change to another face. It's annoying, I understand. Nothing really that you can do to correct other than changing faces.
Hi, this problem can be caused by the CF itself. Fitbit uses Accuweather for updating the weather. It might be that your Clock Face is using another weather provider, like f.i. the Forecast clock face which uses DarkSky as provider. So, I would advice you to check which provider your Clock Face uses to display the temperature.
