Watch Faces With 2 Settings But Only 1 Works
ANSWERED
On a couple of my watch faces (Pleat and Waveform for example) there is a second photo of the display that shows just the time without the stats, but I can’t set my face to it. Why is that? When is the other display used?
1 BEST ANSWER
Accepted Solutions
@epholt   That’s the view you see when you use always on display with those clock faces.
If you put your Fitbit on your ankle when you ride your spin bike, then you just don’t get it.
2 REPLIES 2
Hi @epholt - if you want Always On, swipe the watch face to the right to get to Quick Settings and enable it there, also enable wrist wake.
