Hi All
I went to the gym this morning and one of the my watch straps fell off. I now have a small piece stuck and I am trying to change it but it wont come out.
Has anyone else had this issue?? and how did you resolve it
Thanks
05-11-2023
22:46
14:38
05-11-2023
22:46
14:38
Hi @cooldee1982 - if the strap broke a small piece can get left in but there is a clasp that should be there. So it would be best to take a photo before destroying a part of a perfectly good watch, or just try re-attaching the band if it is just detached and not indeed broken.
At worst try removing the good band and compare the ends carefully.
