Wondering if anyone knows if watch faces are shared across the various Versa watches or does each version have it's own catalog?
I'm asking because I have a watch face on my Versa 2 that I really like, but my battery life has gone down the tubes recently. I'm thinking off replacing it with a Versa 4, but I'm concerned that that face may not be available.
I guess a related question would be if anyone knows a way to browse available faces for a watch before purchase?
Thanks!
01-15-2023
22:26
15:43
01-15-2023
22:26
15:43
Hi @Mnclimber - clock faces are shared, and each watch has it's own version. Because the geometry of the display and functionality of watches are different the developers may or may not port a watch face from one watch model to another.
A lot of things are not available on a Versa 4, such as apps or Google Assistant, and there are a limited number of clock faces because developers cannot develop or support them. A Versa 3 might be a better one as it has more features.
You may be able to resolve the Versa 2 battery issues as this is a great watch normally, so see if you can find the cause, if it is not water damage.Often battery issues can be something else and not battery.
Everything works on the Versa 2 whereas on the later watches there can be issues with poor exercise heart rate, poor vibration, charging problems, so best to check out the forums first, or if the watch does need replacing and is outside warranty, go for another Versa 2 which is considerably cheaper and more reliable.
If you look in the gallery.fitbit.com in your browser you can search for clocks/apps, but it will return clocks/apps for all watches.
If you select one, eg Facet, pay attention to which watches are supported.
