02-03-2023 16:03
02-03-2023 16:03
I used a watchface on my versa2 that showed my minimum heart rate from overnight, as opposed to resting heart rate, but when it's face fell off forcing an update to versa3 I lost my saved clock faces and can't remember what it was called. Can anyone direct me to a watchface for the versa3 that has this metric?
02-03-2023
21:32
07:42
02-03-2023
21:32
07:42
Hi @Paul_p - the Versa 2 has a different geometry to the Versa 3 and not all clock faces are made available across both types, so you may not find it for your new watch.
Though if you search in the Gallery using Google, it will show all clock faces whereas a search in the Fitbit App Gallery tile will only return clock faces that work on your watch.
This will enable you to confirm when you find it on which models it was made available by clicking on devices to expand it.
Best Answer02-04-2023 04:21
02-04-2023 04:21
@Paul_p The Versa 3 has this information without needing a special clock face. If you open your Today app on the Versa 3 itself, then scroll to heart rate, you can tap on that and see your heart rate range. Just to add a little more information. When you swipe up on that heart rate range scree, you see heart rate zones, but they are all "--". That has been a problem since Day 1 with the Versa 3.
Laurie | Maryland
Best Answer02-05-2023 02:24
02-05-2023 02:24
