03-20-2019
18:42
04:17
MarcoGFitbit
03-20-2019
18:42
04:17
MarcoGFitbit
My versa is not counting my water I add. I put my ounces in on versa and it is not updating after sync. Everything else seems to be syncing fine.
03-21-2019 04:20
03-21-2019 04:20
Hello @ney_ney1978, I hope you're doing well, it's great to see you around the Fitbit Community. ![]()
I appreciate your participation in the Forums and for sharing your experience with us. At this moment, in case you haven't done it yet, please update the Today app inside the Fitbit app. Go to Account > Versa > Apps and check that Today does not have a pending update, as this might be the cause why the water logs are not showing up when you logged from from the watch. Make sure to sync your Versa afterwards.
I hope this can be helpful, give it a try and let us know the outcome!
03-21-2019 06:02
03-21-2019 06:02
Hi @ney_ney1978, good to see you in the community.
I believe this is a know issue as acknowledged in this thread here. I think it would be a good idea to keep an eye on that regarding any updates about the problem.
03-21-2019 15:45
03-21-2019 15:45
Thank you for your help! That seems to have fixed the issue. I have never even been to the apps page until you said to. Thanks again!
03-22-2019 12:32
03-22-2019 12:32
Hello @ney_ney1978 I hope you're doing well, thanks for taking the time to reply. @N8teGee It's good to see you around, I hope you're doing well. ![]()
@ney_ney1978 I appreciate you have come back and let us know the troubleshooting steps provided were helpful for you, I'm very glad. In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best Answer03-28-2019 05:22
03-28-2019 05:22
I did as was suggested and it worked for a day. Now back to not logging all water on just device not app. Any others suggestions to fix this?
07-16-2019 05:51
07-16-2019 05:51
Mine is not logging water from device to the phone app either. I tried to update the "Today" app, but it was good as far as I could tell.
07-22-2019 15:44
07-22-2019 15:44
I, too, always have trouble with the data I enter in my watch not showing up on the app.
When is is this going to be fixed? It’s a problem that has been perplexing users for well over a year, at Leafy, and Fitbit still hadn’t found a solution.
08-02-2019 11:30
08-02-2019 11:30
Water Logged doesn't sync. I logged water using watch, and doesn't show up on App. and Vice-versa. I logged water using app, and doesn't show up on App. During the day, and most importantly, At the end of the day, I would like to know how much water consumed, adding both the watch and app together.
08-02-2019 11:33
08-02-2019 11:33
Mine isn't syncing either. Doesn't appear that the Today app has any update
Best Answer08-02-2019 11:36
08-02-2019 11:36
There's no update on the Today app. Both my watch and App are up to date, no updates available. I
@MarcoGFitbit wrote:Hello @ney_ney1978, I hope you're doing well, it's great to see you around the Fitbit Community.
've re-started everything.
08-22-2019 18:48
08-22-2019 18:48
My husband and I are both having this exact same issue with our Versas. We have both tried restarting, resyncing and there are no updates available. Is this going to be fixed?
09-19-2019 06:00
09-19-2019 06:00
I have the same issue and have read all to correspondences in this blog regarding the matter. Nonetheless, the problem remains. Is Fitbit doing anything about this?
09-24-2019 13:13
09-24-2019 13:13
Has this been fixed? I'm having the same issues, app is up-to-date and I've already tried the restart option.
05:37
07:31
SilviaFitbit
09-25-2019
05:37
07:31
SilviaFitbit
No...I've tried everything that's been posted. It's annoying considering this app is preinstalled by Fitbit.
Moderator edit: Word choice
Best Answer06-11-2020 09:55
06-11-2020 09:55
What's the point of these discussions when nothing gets resolved. The fitbit rep signature greeting is plain annoying. Also just gives out the standard "update your app" fix that clearly does not work. I already had to buy the aria 2 becouse my aria 1 stopped working on wifi (another known unfixed glitch) I will be returning the tracker for something that works and has propper customer care.
