10-14-2021 15:52 - last edited on 10-21-2021 13:43 by LiliyaFitbit
When logging water on the versa 2 as FL oz, it changes it to ML. So if you log 73 fl oz, it will show as about 2 fl oz instead. This has been an issue for over 3 years and the only resolution is to go into the app on the mobile device and change it. I want a better solution considering the price of the watch is still high, we deserve better support.
10-15-2021 05:29
10-15-2021 05:29
Hi, in your phone Fitbit App check the settings are correct, click profile photo => App Settings => Units => Water, and then resync the watch.
You can also check your settings here in case they are different. Do remember to hit Submit at the bottom and then sync the watch after. |
