Hi, I know that's always safer to use a CF developed by Fitbit, but how can I achieve it to look the Waveform CF as shown on your homepage of this Community of Versa Smartwatches? If I install it and press settings, I do not see this theme as a possibility. Is this cause I live in the Netherlands? I really like the looks of it. I have the Versa 2 Special Edition. Regards kuzibri
I just installed it on my V2 in US with no issues. Is this what you want and you not get?
I prefer "About Time" by CA which shows same data plus active minutes plus month.
@SunsetRunner Not sure where you assertion "I know that's always safer to use a CF developed by Fitbit" come from.
The SDK provided by Fitbit to the independent developer is very limited and it is virtually impossible to create damage to the watch (in other words you can't install viruses or similar). In addition all apps/clockfaces submitted by independent developers are carefully reviewed by Fitbit.
Hi, I have no problems installing it and then get the theme shown in your image. But on top of the Homepage of the Versa Smartwatches, this CF should also have the possibility to show all the data in white and that theme I cannot find in the settings. Regards kuzibri
Best AnswerHi, thanks for reply. It's not about viruses or the like, but third party cf sometimes can cause problems, such as suddenly not showing steps anymore. Furthermore there is always the problem of (in)compatibility when a new Firmware version is released. In these cases, read the topics about it, it is always advised, also by the Moderators, to install a Fitbit CF. Regards kuzibri
