09-12-2019 12:22
09-12-2019 12:22
I have the Versa. Yesterday my watch started having flickering lines going through it so I did the reset with back and bottom buttons several times in order to get it stop. It stopped and this morning I went to change the clock face and now the weather info will not show on any clockface that offers that feature. I’ve tried several diff clockfaces. The weather app itself on the Versa is fine. I’ve tried shutting the Versa down as well and nope. I even disconnect it from Bluetooth and reconnected it to my Bluetooth. Not sure what else to try. Help! It’s not even a year old.
09-12-2019 12:37
09-12-2019 12:37
Hi, Which Third Party Clock Face(s) are you using? Fitbit uses Accuweather as an API, but when the other CF's use another API, the weather will indeed not show up. Regards kuzibri
Best Answer09-12-2019 12:56
09-12-2019 12:56
Best Answer09-12-2019 13:00
09-12-2019 13:00
Hi, where did you find this CF? If I type in Spoiler in the search bar of all CF's. nothing comes up?
Best Answer09-12-2019 13:07
09-12-2019 13:07
No clue what spoiler means. It’s not the name of the clockface. If you tap in spoiler it brings up my reply comment
Best Answer09-12-2019 13:14 - edited 09-12-2019 13:27
Hi, hi I found the ntprEgh CF, but it does not mention the API it's using for the weather. Read you payed for this CF, therefore I would like to suggest to you the following CF: The One by Olbia Coding. Highly customizable, beautiful (main display an analog clock and pressing on it, brings you to another screen with all the necessary stats - also highly custimizable) and very, very battery friendly with a size of only 16 kB. Use that already for a very long time. Costs, after a trial period of 30 hours 1,1 dollar and it's worth every cent of it. Regarding the weather with this CF, you can just use the weather app that is provided/installed in the Fitbit app and your Versa without any problems. Regards kuzibri
Best Answer09-12-2019 13:26
09-12-2019 13:26
Simple Stats is one of the CFs. The other CF is ntprEgh.
Best Answer09-12-2019 13:28
09-12-2019 13:28
Hi Jen, see my updated post just above yours!!
