Weather app current location got deleted-Versa
I messed up when adding a new location to the weather app on the watch. When I added a new city and accidentally deleted the current location option. Is there a way to get that option to come back?
Moderator edit: added label
8 REPLIES 8
Hey @bmoore118, it is nice to see you around more often! Remember that Weather app shows your current location, which can't be deleted. If the weather for your current location doesn’t appear, check that you turned on location services for the Fitbit app. For instructions, see How do I allow the Fitbit app to use my phone's GPS?
If you change locations, sync your watch to see your new location in the Weather app.
Let me know how it goes!
Heydy | Community Moderator, Fitbit
When setting up new location for the weather app, I accidentally deleted my "current location." How do I get it back. Everything I read says that it can't be deleted; however, I did.
Welcome aboard @getFit01! That is correct, your current location can't be deleted and it appears by default as long as you have location services on. Let me suggest you something, please restart your Versa by following the instructions in this post and then sync your watch with the Fitbit app.
Let me know if that works!
@getFit01  When you look at your weather screen, can you swipe left/right to see your current location and other city?
Also, check the weather settings.  From your dashboard, tap on your Versa icon > Apps > Weather > Settings.  Does it list Current Location and your added location under the list of cities?  If Current Location is not on the list, can you post a screen shot?  When you edit the list of cities, Current Location cannot be deleted.  If you managed to delete Current Location, then yes, you managed to delete something that cannot be deleted.  But I am hoping that you didn't -- and just need to swipe left/right to see your cities.
Laurie | Maryland
I’ve restarted the Fitbit, re-synced it, and still nothing. I have in fact deleted “current locations” from the list of cities.
I have done the same thing, I deleted the current location from the weather app by mistake, how do you het it back, I only want the waether for the current location.
I did the same thing. Fixed it by uninstalling and reinstalling the app.
This FitBit weather app is pathetic - i set the locations and then within two weeks they've self deleted and I have to go into the app and reset them.
