I just received the Versa 2 and the weather app is not working correctly. it supposedly updates my location but the time is way off on the opening screen, and it never changes. I have tried uninstalling app from phone { galaxy s7} the day is correct . I tried resetting the fitbit. the location is not exact it is acually the next town over. Just wondering if anything i can do or is this something i have to live with. I wanted to uninstall the app and re install but it wont let me. thanks
01-08-2020
09:03
09:08
01-08-2020
09:03
09:08
@fbnewbie18 Welcome! It's great to see you around! Sorry for the delay in my reply.
Let me help you with your weather app and thank you for troubleshooting this issue. You could try a factory reset. Note that you will need to setup and update your Versa 2 after this.
Let me know how it goes.
Best AnswerThanks for the reply. It did work. The only problem I seem to have now is that every other day I have to force stop my app and restart it to sync. My phone tells me it cannot find device on the bluetooth. Thanks again
