11-18-2023 17:47
11-18-2023 17:47
How do I setup my weather
11-18-2023 23:13
11-18-2023 23:13
Hi @jslabgirl - it normally doesn't require setup. It should show by default weather where you are if the watch is syncing which may not be the case with the new app.
Try holding the button for 10 seconds till it vibrates and the logo appears and wait for it to start.
Also restart the phone and sync, then check weather on the watch by a swipe up of your Versa 3 watch face.
11-19-2023 01:01
11-19-2023 01:01
11-19-2023 01:14
11-19-2023 01:14
@jslabgirl- have a look here where to set units How to change Temperature - for Weather, Centigrade - Fahrenheit, Versa 3
11-19-2023 06:40
11-19-2023 06:40
11-19-2023 07:11
11-19-2023 07:11
@jslabgirl - I know it's confusing as they changed the navigation in the new Fitbit App, click the watch device icon at the top of the Fitbit App first screen instead, then Gallery etc.
11-19-2023 08:55
11-19-2023 08:55
