09-05-2019 08:20
09-05-2019 08:20
I am having a problem with the AccuWeather display on my Versa. The information comes up as Celcius°. Everything else is correct (location, precipitation%, etc...)
I have tries to troubleshoot everywhere I can. I have checked, changed, and re-set in the advanced settings (they are all set to standard such as feet, miles, pounds, etc). I have shut down and restarted my device. I have re-synced it following all of the changes and changing back (even tho it's on auto sync).
I am literally out of options of remedies that I can find.
Does anyone have any possible insight as to why my device wants me to do more math in my head than what it's capable of doing without a conversion chart or paper/pencil? I guess I should have paid more attention in HS science class! ... it needs to get on the same page as me, bc I'm not in Canada or Europe.
Thanks!!
09-05-2019 09:41
09-05-2019 09:41
To change the units used for the temperature in the Weather app:
Best Answer09-05-2019 17:40
09-05-2019 17:40
I dont know whon you are JohnnyRow, Mr. Marathon Racer!! But you got me squared away and now I can successfully tell whether to wear a jacket or not!
Thank you for being more helpful than the GoogleBox.
Safe marathoning!
Best Answer09-05-2019 18:29
09-05-2019 18:29
Glad you got going okay now, @Tracey507
I am definitely no marathon runner. Those running categories under posters names are assigned automatically, based on amount of activity on the forums.
