01-30-2020 07:18
01-30-2020 07:18
The last 2 days, the weather on my Versa 2 is showing in Celsius even though I have all my settings set to Fahrenheit. I have even attempted switching to Celsius, and then back to Fahrenheit but nothing. I have synced, updated, followed all the steps to ensure that my settings are correct but nothing.
01-30-2020 07:49
01-30-2020 07:49
never mind - I figured it out 🙂 it was a setting on my clock face that must have changed if anyone is wondering.
11-07-2021 08:31
11-07-2021 08:31
just chiming in that this helped with my Sense, too. I switched from android to iphone and was having this issue, even though the top level fitbit app setting was set to fahrenheit. Under Gallery, I found settings for just the Weather app, which was on celsius
12-26-2021 21:05
12-26-2021 21:05
Thank you! This was driving me nuts. Your solution worked.
Best Answer01-02-2022 17:05
01-02-2022 17:05
You are a lifesaver-- thank you for posting the solution-- the Celsius setting was making me crazy, too! 🙂
Best Answer01-17-2022 00:57
01-17-2022 00:57
This was super helpful and I solved the problem through the gallery section under the weather settings. Super weird bug that should be fixed. It doesn’t make sense to set the app to Fahrenheit if then you still need to go through the gallery settings to set it there as well. Not very user friendly on that end, def something developers should fix
04-12-2022 09:16
04-12-2022 09:16
Very helpful! I would never have figured that out had you not posted it. Thank you!
