03-07-2019 04:47
03-07-2019 04:47
My accuweather on my phone says something completely different then on my Versa. I have synced at home one WiFi a few times and it still isn’t correct. How do I fix this. It’s only -2 degrees on my phone but -19 on my Fitbit. Please help
03-07-2019 05:15
03-07-2019 05:15
Hi, are you using a Third Party Clock Face? If yes, what's the name of it??
03-07-2019 05:49
03-07-2019 05:49
03-07-2019 06:08 - edited 03-07-2019 06:09
It automatically is at celcius, if you want farenhiet, you have to manually change it. This could be why your versa isn't matching your phone.
To change this, go to: versa, apps, weather... click on the gear shift on the right... and click on settings. Hopefully this helps.
03-07-2019 08:03
03-07-2019 08:03
03-07-2019 08:05
03-07-2019 08:05
Your welcome 🙂
