02-15-2019 01:25
02-15-2019 01:25
When I select "Weights" under the exercise menu, instead of having the timer like all other options do (run, treadmill, bike, etc) it shows "Laps" as below:
Show Laps - off
Automatic Lap Setting
Customise stats
It no longer has the timer. If this is a deliberate change that's been forced through, I want to roll back to the previous version, as I find the idea of "laps" with weights ridiculous. You do laps while swimming, not lifting weights, and I use time as a way to measure that.
02-20-2019 11:17 - edited 02-20-2019 11:18
@ThinRedLine It is still there. Please do the following:
Hope that helps.
Best Answer02-15-2019 14:24
02-15-2019 14:24
@ThinRedLine Fitbit calls the cues laps. What it means it can divide your exercise based on calories, time and distance depending on exercise. You do not need to turn this setting ON. By the timer do you mean time elapsed? It is a stat that can be configured under Customise stats option. You can select which stats will be displayed on top, middle and bottom of the screen. You can have several stats in the middle of the screen and just tap to switch between them.
02-19-2019 01:29
02-19-2019 01:29
Must be an American thing, I've never heard of it before. Sucks that I lose that information, but at least I don't have to try to jam the watch up under my weights gloves now. I still don't get it. Must have been thousands asking for the change...
Best Answer02-19-2019 11:35
02-19-2019 11:35
@ThinRedLine But, is it Time Elapsed that you need? What exactly would you like to do?
Best Answer02-20-2019 02:00
02-20-2019 02:00
It is time elapsed I want. I want to push "start" when I start my weights workout and "stop" when I finish, and have it record that as activity done. I don't do... "laps" of the weights room, I just move from machine to machine. That's what it used to show/record before the latest update.
Hope that helps.
