05-21-2018 22:03
05-21-2018 22:03
Just got a charge 2 & I love it.. so I def could see myself getting the Versa or Ionic in the next few months.. what are the main differences between the two? Which would someone recommend? (I wear mine all the time & measure calories etc during my workouts)
05-21-2018 23:00
05-21-2018 23:00
From what I understand, the only difference between the two is that the ionic has built in gps and versa has connected gps. That’s why the ionic is $100 more.
05-21-2018 22:51
05-21-2018 22:51
They are basically the same thing. The versa has the women health on the watch.
Versa is sleeker in design. I myself would get the versa.
Wendy | CA | Moto G6 Android
05-21-2018 23:00
05-21-2018 23:00
05-22-2018 17:37
05-22-2018 17:37
Thank you!!
05-22-2018 17:38
05-22-2018 17:38
Thank you so much! I think the Versa is probably a better choice for me personally— Thanks again!
05-23-2018 04:09
05-23-2018 04:09
Hello,
Just to chime in here. If you frequently use GPS activities (walking, running & cycling) then be aware that the Connected-GPS on the Versa can be sporadic and unpredictable at times. There are multiple threads on these boards regarding issues with it (including my own experience using it). That's not to put you off buying one, but know that the built-in GPS on the Ionic is far better performance-wise.
However, if GPS tracking isn't your main thing and you just want daily fitness tracking then the Versa is perfectly fine. Though both watches are classed as unisex, one could argue that the Versa is geared towards women and the Ionic, with it's 'masculine design' (as I frequently read), is considered geared towards men.
05-23-2018 05:12
05-23-2018 05:12
What about the sensor for measuring breathing that the ionic has but isn't activated yet? Does the versa have this sensor?
05-23-2018 05:27 - edited 05-23-2018 05:27
Do you mean the Sp02 sensor? If so then yes, according this page*, the Versa includes the sensor. Though when/if it will ever be activated is anyone's guess.
*Scroll down, expand "See all features" and click on the 'Design Specs' tab to see the list of sensors and components on the Versa.
