08-07-2020 09:45
08-07-2020 09:45
When I'm inside, my screen is fine, but when I'm outside, it is dark and I can barely read it, if at all. How can I change this? It has only started happening (last 2 months or so) and it is really annoying. Not sure if it was part of an update. I'd rather see it easily when I'm outside.
08-07-2020 10:31
08-07-2020 10:31
Check Brightness under Settings. 'Normal' says it auto-adjusts to lighting conditions.
Best Answer08-07-2020 11:08
08-07-2020 11:08
Best Answer08-07-2020 11:11
08-07-2020 11:11
Thank you. But where is this setting? On the watch or in the app? I see the quick settings on the watch has dim, normal, and bright, but no other info and can't find that on the app.
Best Answer08-07-2020 11:18
08-07-2020 11:18
Settings on the watch. With 'Normal', it says 'Auto-adjusts to lighting conditions', at least on Versa 2.
