04-14-2018 10:35
04-14-2018 10:35
Finally got my Versa this morning. The WiFi connection issues in the ionic seem to be the same on the versa. The WiFi connection won’t stick and will completely drop after about 10 minutes. I can force a WiFi detection of my home WiFi with a reboot but it doesn’t stick. Very annoying. I hope hey fix it soon.
04-14-2018 13:46
04-14-2018 13:46
The Ionic and the Versa share the same operating system. When they resolve this or any other issue they will likely upgrade both.
04-14-2018 13:46
04-14-2018 13:46
09-20-2018 13:03
09-20-2018 13:03
Biggest day of My Versa has been fine until today ..Will not sync and does not see my wifi
Has been connecting with no issues for 5 days now does not see my wi fi
12-26-2018 09:08
12-26-2018 09:08
Versa sucks! No WiFi connection ! VERY Disappointed!! I will be trading it in for an Apple Watch!sucks
12-26-2018 09:26 - edited 12-26-2018 09:32
Hi, this issue can be solved: in order to keep your WiFi on your Versa connected, you will need to do the following:
1. Your Versa has to be in the charger and connected to PC.
2. Go to your Fitbit app on you mobile device, go to the page where also Clock faces are shown and scroll down to WiFi settings. Click it
3. You should see your WiFi network now with on the right side of the screen a white icon.
4. Press this icon and it will start connecting to your network
5. Once it is connected, this icon turns to blue and says "connected"
This connection lasts as long as your Versa is in the charger and connected to your PC, otherwise it will disconnect after a few minutes. Good luck and let me know if this works for you.
Best Answer12-26-2018 09:31
12-26-2018 09:31
Best Answer12-26-2018 09:36
12-26-2018 09:36
Hi, it does not suck, it's just simply the way the Versa works to be connected to WiFi as it does not have WiFi itself and it works the way I described.
Best Answer12-26-2018 16:17 - edited 12-26-2018 17:07
Hi, unfortunately I have to conclude that the answer, that is marked as accepted solution, does not solve the mentioned problem and thus should not be as such considered as an Accepted Solution. I performed my posted procedure already for the Ionic and it worked also flawlesly. Very sorry for that Patruns.
01-22-2019 19:30
01-22-2019 19:30
It does not work as described.
Best Answer01-22-2019 19:31
01-22-2019 19:31
It does not work as described.. sorry. This needs to be fixed.
Best Answer04-18-2019 08:20
04-18-2019 08:20
I have Spectrum internet and my Versa cannot even find it. Are you saying that I cannot use my IPad to connect to the WiFi to download data from the Versa unless connected to a PC. I’m confused. I have the app on my IPad.
Best Answer04-18-2019 08:24
04-18-2019 08:24
Best Answer04-18-2019 08:27
04-18-2019 08:27
I am also dealing with this and have been for a couple months now. I am extremely frustrated as the watch should simply connect and update via bluetooth instead of annoyingly never connecting via wifi. I am very over this watch and just want my charge 2 back.
