Hello,
is there any plan to allow us to connect our fitbit to a wifi with a login? I know it doesn't work right now, but is their plan to modify it and let us?
Both my university and work places have logins, and since I can't connect to wifi, I can't get the notifications from my calendar to remind me to take my meds (I have a brain injury, and those reminders is the whole reason I bought this watch).
I have also tried the "in fitbit apps" to sync calendars and agendas and they failed epically, so the only way I have found thus far to get a reminder on my watch is to always be connected to wifi and bluetooth to my iPhone. If someone has any ideas of how to fix that, it would much appreciated too.
Thank you for your help
@encie93 The notifications are not being sent to your watch via WIFI but via bluetooth. You need to enable calendar notifications in the Fitbit mobile app. Which operating system are you using? Android or iOS? Please open fitbit app, tap on the Versa icon, scroll to Notifications and under Calendar Event enable your Calendar app. Good luck!
