09-15-2020 07:33
09-15-2020 07:33
Zone minutes are not reflecting calorie burn. I just walked for 31/2 hrs on a treadmill at a 17 pace which for me is very fast. If this had been active minutes the calories burned would have been more. Not that active minutes were all that great but much of this stuff is so inaccurate
09-15-2020 11:35
09-15-2020 11:35
Since the update, I too have been experiencing the same issues. My web browser dashboard says that today already I have had 26 active minutes, but on my phone and watch, it only reflects 17, even though this morning I have a 40 minute workout and to top it off, even when I do hit the "zone" goal, it sometimes will not account for my daily goals. When I contacted tech support yesterday, they didn't help much. It's frustrating to pay as much as I did for this band and it only work 1/2 the time 😞
Hopefully your issue is resolved soon!
09-15-2020 15:11
09-15-2020 15:11
@Rosalitaspinoza and @Hannamomof2 -
I am going to hopefully address both of your concerns and then generalize about the new firmware.
Calorie Burn:
I have a routine that includes one hour on the treadmill at a pace of approximately 20:00 (3 mph) at least twice each day.
Before and after the firmware update that gave us Active Zone Minutes for Active Minutes, calorie burn reported has been consistently between 408 and 424 calories, or 6.8 and 7.1 per minute - even with the device sometimes stating I was "under zone". The only exception to those numbers was a two day period where we had a mini-heatwave here in Southern California where it got up to 108 degrees in the garage where my treadmill is. I got up to 444 calories one day or 7.4 calories per minute.
My observation is that the calorie burn calculation has remained consistent to what it has been since I started wearing a Heart Rate sensing device in July of 2017.
Active Minutes vs Active Zone Minutes:
The web dashboard continues to report Active Minutes instead of the Active Zone Minutes the Versa Family of devices and, by association whatever mobile app your device is paired with. Continuing to use Active Minutes on the Web Dashboard is probably to remain consistent with the rest of the FitBit population. Why they cannot change the reporting on the web just like they do in the app is beyond me, laziness, I suppose. Or maybe they just think people always have their face in their phones.
FitBit has apparently rethought its definition of "activity".
They have also, as you have seen, replaced the traditional formula to define heart rate zones with a new "Heart Rate Reserve" formula, where a percentage of your reserve (Max HR - Resting Heart Rate) is added to your resting heart rate.
40% of the reserve is added to your resting heart rate to establish the beginning of the Fat Burn Zone.
60% of the reserve is added to your resting heart rate to establish the beginning of the Cardio Zone.
85% of the reserve is added to your resting heart rate to establish the beginning of the Peak Zone.
As far as the new zone definitions, here is a chart outlining the changes as they affected me:
The newly defined zones are quite often referred to as "Training Zones" because the formula in use was created for the purpose of more clearly defining the zones for athletes in training. A FitBit Community Council member whose opinions and support in the boards I happen to admire, in an attempt to defend the new zone structure pointed me to a New York Times article regarding HRR. But everything in the article seemed to be about athletes in training, including an Olympic hopeful in canoeing, and not your regular John and Jane Doe.
Do I believe that FitBit has done their users a disservice by not allowing them to opt out of Active Zone Minutes and, by association, the new zones?
YES
But my voice doesn't count.
Have a great day and welcome to the boards.
09-16-2020 09:46
09-16-2020 09:46
Thanks for the explanation. When I change my heart rate zones in the app, for a more customized plan, they do not update to my Versa Lite tracker? Advise, help?
Best Answer09-16-2020 10:43
09-16-2020 10:43
@Adrixx -
There is a bug, at least in the iOS app, that does not allow for setting a custom Max HR value.
However...
You can change it in the Settings page in the Web Dashboard
Scroll down to Heart Rate Zones and expand the tile by clicking on it.
Select "Custom" under "MAX HEART RATE" and enter your new Max HR.
Save the change by clicking on "Submit" and sync your device.
You can review your new zones by clicking on the app's Heart Rate tile and then on the "gear" icon at the top right of the screen. You may, or may not see the Custom Max HR value (it is pretty much a crapshoot), but if the zone values changed, you are good to go.
Of over a dozen people that have tried that method when I recommended it on another thread, only one individual could not get it to take. And one person had to log out of the app and back in for it to take.
And you need to stay on top of it. The FitBit servers routinely reset the Custom Max HR override back to the "default" value of 220 - age. It has happened to me three times in the past 2 weeks.
Good luck.
09-16-2020 11:14
09-16-2020 11:14
It worked great! Thank you!
It does a custom section highlighted in green, separate from what Fitbit has as my Zones. Happy I could get this figured out.
Best Answer09-16-2020 12:10
09-16-2020 12:10
@MrMarv I didn't try it as I'm getting more calories burned and active minutes with zones, but I noticed in the android app settings yesterday, there is an option to turn off zone minutes.
09-16-2020 12:36
09-16-2020 12:36
@MarkMM -
Glad you are happy with what you've been given - that's all we can ask for, right?
When did the option to turn AZM off hit Android? I noticed 3.30 for iOS came out yesterday, but haven't taken it on yet.
I really don't care that much, other than how it is being handled/mishandled. With the ability to set a Custom Max HR to deal with the heart rate throttling that Beta Blockers throw at me, I'm okay with it either way. I just wish FitBit would quit resetting it.
I know where I need to be as I listen to my cardiologist and NOT FitBit when it comes to where my zones are.
If you are wondering why, I have an ICD and a LVEF of 20% (or less than half what is considered "needed" and less than a third of what is considered "desirable". All from a viral attack in early 2017. If you don't already know, an ICD is an Implantable Cardioverter Defibrillator (pacemaker with an onboard Defibrillator) and LVEF is a measurement of how much of the blood in my Left Ventricle leaves when my heart pumps.
