01-19-2019 18:05
01-19-2019 18:05
I am trying to switch from one face to another, but keep getting message that it is "unable to connect to Versa. Make sure your fit bit is nearby and powered on and try again". I am wearing my fit bit and it is fully charged . What the heck do I do?
01-19-2019 22:01
01-19-2019 22:01
Actually--surprise-- my own human error.Did not have Bluetooth turned on in my Versa app, only on my phone. Problem solved. Thank you!
01-19-2019 18:27
01-19-2019 18:27
What phone are you using? Sometimes that makes a difference
Helen | Western Australia
01-19-2019 19:16
01-19-2019 19:16
Samsung Galaxy 7
01-19-2019 19:45
01-19-2019 19:45
Being a Galaxy Android device, the first thing I would do is clear the cache of the Fitbit app. Then restart the phone, Android still has memory management problems.
I think I would then restart the Versa by holding in both the left and lower right buttons.
Have you had problems syncing?
01-19-2019 22:01
01-19-2019 22:01
