10-14-2019 12:29
10-14-2019 12:29
Hi all 🙂
The left hand side button is stuck pushed in and doesnt move at all
Iv tried all the tricks of cleaning it, from what iv read from forrums.
Yet it is still stuck 😞
10-14-2019 12:32 - edited 10-14-2019 14:04
@llamadelray Contact support: https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Is it out of warranty?
If not? Do not do this.
Using a small fine needle. Carefully see if you can lift the left button to release it. It may just be a really small 'fine piece of dirt' making it stick.
Buttons on mine started to stick so I applied a very small amount WD40 off end of said pin to lubricate them.
If you are not confident enough to do this yourself go to a jeweller, an horologist (person that repairs clocks & watches) or a watch repair shop. Hope you get it sorted.
