my versa time keeps messing up and wont change back to the actually time when i connect to my phone. Does anyone know how to fix this problem
Hi @clove3857 , are you using a Third Party Clock Face? If yes, change it to one developed by Fitbit itself and restart your watch. The problem should be solved by this. Regards kuzibri
Best AnswerHi @clove3857 , are you using a Third Party Clock Face? If yes, change it to one developed by Fitbit itself and restart your watch. The problem should be solved by this. Regards kuzibri
