04-04-2020 13:37
04-04-2020 13:37
plse help me to unlocked my versa....its stated device lock block.
04-04-2020 22:09
04-04-2020 22:09
Hi @ZarinaDollah Try restarting the Versa several times. If that doesnt fix it then you will need to try a factory reset and then (hopefully) that will fix it and you can set the device up again. If it doesnt help then you will need to contact Customer Support
VERSA FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
Helen | Western Australia
