11-30-2020 07:56
11-30-2020 07:56
I updated firmware recently.
Worked fine last week.
Problem started in last 2 days.
Versa 2 would not sync with app in morning unless I restarted Versa.
I was able to sync today at 9 AM after restarting Versa.
At 10 AM it would not sync.
Restarted phone. Restarted Versa.
No sync.
I removed Versa 2 from app intending to reconnect.
Now I can't pair it.
Help. Was it the firmware update?
11-30-2020 10:25
11-30-2020 10:25
Hi @RichardMW sorry about the problems.
Yes removing the tracker from your account when you already know the app is unable to talk to the tracker is a big mistake.
BTW You don't have to remove the tracker to set it up as a replacement device.
We still have to fix the sync issue and then we should be able to setup the tracker as a new device, probably losing all unsynced data.
Let's look here for sync problems, for setup instructions, and setup problems.
