09-29-2019 16:54
09-29-2019 16:54
My versa lite was way off on the time and wouldn't sync. I hit the reset and now how do I get it back? It just scrolls to in all kinds of languages and I think it says to get the app. I have the app already on my phone and computer..
Best Answer09-29-2019 17:38
09-29-2019 17:38
You have to pair the device with your phone again. On your phone open FitBit app. Top left select your icon. Go to settings. Scroll down - Set Up A Device.. Ensure your tracker is on charge before you do this. Then follow on screen prompts.
Best Answer09-29-2019 17:47
09-29-2019 17:47
Best Answer09-29-2019 17:50 - edited 09-29-2019 17:59
Doing as I said 1st reply would have given you the option to delete previous paring.
To do so manually:
Select icon for Versa in the menu.
Scroll down.
Remove this Versa - then follow instructions as above.
Here is the user manual: https://staticcs.fitbit.com/content/assets/help/manuals/manual_versa_en_US.pdf
