snorkeling and scuba diving with versa
ANSWERED
May I use my versa while snorkelling in salt water?
May I use my versa while diving above 50m in salt water?
1 BEST ANSWER
Accepted Solutions
Hi @goitz,
1. Yes, just rinse off the salt water afterwards and it'll be fine.
2. No, the impact from diving would be harmful to the watch.
Work out...eat... sleep...repeat!
Dave | California
4 REPLIES 4
Hi @goitz,
Dave | California
Thank you sir!
I use the versa watch  when I am swimming in a beach when I go back and put the watch on the charger the watch come very hot from the battery side and it seen its not charge I remove it and put it again it is charged full but it's paused on notification show and I can't see anything even the notification when I press the button no answer
As mentioned in previous replies, it is important to rinse off the salt water from the watch and then dry it.
Water conducts electricity and salt water is an even better conductor. The heat you feel may be caused by "shorting" of the tow ends of the battery. I suggest you rinse the watch in fresh water and then dry it before you charge it  Hope this helps.
