Hi @PJsteez , are you using a Third Party Clock Face? If yes, change it to one developed by Fitbit itself and restart your Versa and the problem should be solved. Third Party Clock Faces are known to behave suddenly erroneously for whatever reason, either cause the Developer did not update the CF or just because this particular CF is incompatible with the newest Firmware version, Erik
