03-04-2022
14:23
20:21
03-04-2022
14:23
20:21
I am using the versa 3 for run/walk intervals. At the end of an interval the versa 3 vibrates once. I often miss the vibrate when running. How can I add sound or a stronger vibrate?
03-04-2022 23:26
03-04-2022 23:26
Hi @rungw - unfortunately the vibration on the Versa 3 and Sense is weak and easily missed. There is no sound alert capability.
Also vibration gets weaker as the battery level falls so if you are using GPS as well it will get progressively weaker.
The only thing is to fully charge and experiment with how it is worn, but I never found a way to get a reliable improvement.
05:04
07:06
03-05-2022
05:04
07:06
Hello @rungw and welcome to the Community. There is a vibration setting on the device. Swipe left on the screen until you get to the Settings app > Vibration & Audio > choose Strong. Also, please make sure your Fitbit isn't too loose when exercising. I'm sorry, but the Exercise app isn't programmed to give a sound cue.
My experience with the Versa 3 vibration is much different from @Guy_. I am thankful that there is a Sleep Mode or vibrations from (rudely timed) notifications would wake me.
Laurie | Maryland
