versa - play only one song repeatedly even though there are 47 songs displayed on the versa watch. I clicked on "next" button, still the same one song play repeatedly.
It takes quite a long time to login to Fitbit Connect. I am using Window 8.1. Kindly assist
Hi, unfortunately you are not able to transfer music to your Versa with Fitbit Connect. Do you have a Tablet? If yes, install the Fitbit app on your tablet, although it will tell you that's not made for a Tablet, but ignore that and install it. Perform the entire Setup procedure to connect your Versa to your tablet and when that's succeeded, you will be able to transfer Music from your tablet to the Versa using the WiFi connection.
