Hi @NannyOgg. First, please make sure you have v. 4.66 of the app. If you have it, tap on the Health icon in the lower right of the app. Scroll down to the All data section. You’ll find it there.
Laurie | Maryland
Best AnswerHi @NannyOgg. First, please make sure you have v. 4.66 of the app. If you have it, tap on the Health icon in the lower right of the app. Scroll down to the All data section. You’ll find it there.
Laurie | Maryland
Best Answer@NannyOgg. It is rolling out now.
Laurie | Maryland
Hello @NannyOgg.
I believe All data is what iOS users see. If you're an Android user, tap the Health tab, and look under Focus areas. There's a tile for Cycle health.
@NannyOgg. My usual go to is to delete the app, then reinstall it. This feature was specifically listed as being added in v 4.66. Pinned thread
Laurie | Maryland
Best AnswerHello @NannyOgg.
Do you see the Menstrual health cycle if you switch back to the regular Fitbit app? If so, you may need to switch back for now until the tile shows up in Public Preview for you.
Since you already tried uninstalling, then re-installing the app without success, please submit this issue using the Feedback option in the Fitbit app:
Include your Fitbit app version and phone info in your feedback report.
Although it's likely that you won't receive a response, we've gotten confirmation that the team reviews every feedback report and uses the information for issue investigation.
