Hi @LabMom65, thanks for explaining why you would like to use temperature and humidity to increase calories burned accuracy. Thanks for sharing your feedback. I've moved it into a similar request. A lot of users are asking for this option, I hope we receive updates soon. You can also vote for this other suggestion: Consider adding “chores” or “yard work” as an activity.
When it is hot out we burn more calories sweating trying to regulate our body temp. So for example if it is 75° out light wind and it's perfect weather you burn say 1000calories over 4miles. Now conversely you walk another 4miles and it is 98° with 95% humidity, now you burn 1800calories. Add weather calorie adjuster app to track weather's effects.
Hi @GayRehabProject, thanks for taking the time to share this suggestion about taking in count weather temperature to improve calories burned. I've moved it into a similar request. You can learn more about how Fitbit decides what suggestions get released in our FAQs. Click on the thumbs-up to show your support.
Thank you again for your participation in the Feature Suggestions Forums.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
