Hi @annasounantha thank you for your suggestion, which has been incorporated into Aria 2! A quicker set up and updated Wi-Fi technology on the newly released Aria 2 should address this issue. Aria 2 a reengineered Wi-Fi Smart Scale that offers the latest technology to capture your data with greater precision than ever before. Thanks for taking the time to share your thoughts with us.
I just replaced the batteries on my Aria scale. It got stuck on the active set up mode. To fix it, I had to download the scale's set up software onto my computer, then go through the wifi connection setup again, following the instructions here: https://www.fitbit.com/en-ca/setup/aria?platform=mac&step=2. This needs to be far simpler... as easy as replacing the batteries and stepping on the scale with all settings remembered.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
