Hi @Lmoore1215 embr wave seems to put a jolt of cold to the wrist and it larger than any of the Fitbit devices. It probably uses a great deal of power to put out that cold temperature, so I'm not sure how it would be incorporated into the Fitbit devices. There is a temperature portion of the devices that would thrown off totally by an artificial cold placed on the wrist.
Hi @Lmoore1215, thanks for sharing this suggestion adding Embr wave technology on Fitbit devices. Our web API and smartwatch SDK are open which means that the service you are wanting can actually integrate with Fitbit. We’d encourage you to make this suggestion to the service and direct them to our existing API and SDK and resources such as the web dev API community. You will likely be able to email them via their contact us page or customer support, or they may have their own ideas board like this. Or encourage them to reach out to Fitbit directly.
Thanks for your participation in the Feature Suggestion forums, we look forward to making Fitbit more useful for you.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
