I would like Fitbit to more accurately set my sleep and wake times.
I would like to add more information to the process of analysis.
For example, I would like to set my typical wake up and go to sleep times. (Then the algorithm could try to fit my current data).
I would also like to set that I typically have one sleeping period.
Currently I need to adjust the sleep record almost every day either by moving one of the times or by deleting an extra record. (For example an eight hour record might be broken up by you into three hour and five hour sections initially). Using versa 3.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
