Versa 3 is not currently compatible with iTunes and it is a downgrade in the music capabilities from the previous versions. Make them compatible!!! Please!
Hi @Miss.t did you ask Apple about this? It might be they would need to approve the use and since they have a competing product, they might not want to have this happen.
Hi @Miss.t. Thanks for sharing this suggestion about having an integration between iTunes and Versa 3 with us. Our web API and smartwatch SDK are open which means that the service you are wanting can actually integrate with Fitbit. We’d encourage you to make this suggestion to the service and direct them to our existing API and SDK and resources such as the web dev API community. You will likely be able to email them via their contact us page or customer support, or they may have their own ideas board like this. Or encourage them to reach out to Fitbit directly. Thanks for your participation in the Feature Suggestion forums, we look forward to making Fitbit more useful for you.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
