Integration between Starting Strength app and Fitbit
I would like to import my workouts from my starting strength app (https://startingstrength.com/index.php/get-started/equipment). I can export records in the form of a csv from the app. Would be cool if fit bit could track potential calories burned by body weight, weight lifted type of lift. I think many would live this feature/interoperability
Moderator Edit: Clarified subject and updated label
1 Comment
Status changed to: Not currently planned
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @edlovesiraq.Thanks for sharing this suggestion about making an integration between Starting Strength app and Fitbit app with us. Our web API and smartwatch SDK are open which means that the service you are wanting can actually integrate with Fitbit. We’d encourage you to make this suggestion to the service and direct them to our existing API and SDK and resources such as the web dev API community. You will likely be able to email them via their contact us page or customer support, or they may have their own ideas board like this. Or encourage them to reach out to Fitbit directly. Thanks for your participation in the Feature Suggestion forums, we look forward to making Fitbit more useful for you.
