Interval workout more intervals
Hi
Currently it is possible to add only two intervals in interval workout.
It would be great to have more intervals for example: 1min move 1.5 min rest, 3 min move and 3 min rest and so on and then repeat that.
21 Comments
Status changed to: Reviewed By Moderator
EdsonFitbit
Fitbit Moderator
Fitbit Moderator
@SunsetRunner Thanks for your suggestion to add more intervals to the Interval Workout feature.
Let's see what other Community members think and once any update be available it will be communicated as soon as possible.
Tracey1974
Jogger
Unlimited intervals not just to 49. Distance running training needs more than 49 intervals, quite a basic request I think
Status changed to: New
JuanFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @Tracey1974 Nice suggestion, thanks for sharing. I've moved your suggestion to this one, as they are very similar. We look forward to hearing what other community members think
welljim
Jogger
Ability to configure custom intervals of our required duration would make much more sense than having to select from a pre-chosen interval duration. And yes, more of them. A lot of circuit training routines have a ton of different intervals.
starl
Recovery Runner
I'd like the options where you can setup
Move (ie 30 seconds)
Rest (ie 10 seconds)
# of times to repeat (the above, ie 6 times)
Rest between sets  (ie 2 minutes)
# of sets (ie 3)
Else, I'm doing an interval - it stops. I wait 2 minutes, start my watch again, it stops, wait 2 minutes, start my watch again...
Intervals are sometimes repeated after a rest. The current setup is more useful for a single Tabata rotation
KatjaKat
Jogger
Customisable intervals would be incredibly helpful. I'm starting back on the Couch to 5K (C25K) program as I've lost my form lately and the current intervals would only work for the first couple of weeks. After that it's variable length intervals with variable length breaks. I can set this up on the Endomondo app and save them for later but it would be better to be able to do it directly in the Fitbit app. If I track my run with Endomondo the calories burnt seems to come from Endomondo and not based on heart rate, and also the auto tracking feature means my run gets logged twice which is annoying.
mariac1210
First Steps
For interval Training (HIIT) sessions, which I think this is designed for, it is common to do 3 reps per set of exercises, with a short break in between reps but a slightly longer rest period between sets. It would be good to get extra flexibility in this similar to what Recovery Runner is suggesting.
For example:
Move   -   50seconds
Rest    -   10seconds  (between reps)
Reps   -   3
Sets    -  10
Pause - 30seconds (between sets)
For anykind of interval training this is a must and each of the above bolded items should be configurable to suit the type of training being done. This would make FitBit much more of a one stop shop for me!
twingo99
Jogger
I have a couch who is sending me training plans for halfM preparation. At the moment, training looks like this:
10 min run
1,5 min walking
10 min run
1,5 min walk
5 min run
It would be very  helpful if I could pre-set those times and just follow vibrations on my hand.
Future training's will be in kilometers like:
2 km run
200 m walk
2 km run
300 m walk
Tnx in advance for helping us to reach our goals easier 🙂
TrimFit
First Steps
Like Katka Kat Jogger, I'm doing Couch to 5k and the intervals work week 1 and 2 but I can't add anymore intervals. I think this would be a help.  I have a charge 2
SunsetRunner
Not applicable
Turns out the only good solution is to switch to Garmin or Polar fitness watches.
TrimFit
First Steps
Haha! Thanks for that advice!
Coconutsyogi
Recovery Runner
Yes, this is a must. Any interval tracker needs multiple interval setting options. I need to be able to set at least 3 intervals for my training, hard, slow, and rest. I am very disappointed that Fitbit doesn't have this feature. It's got me considering going back to the iWatch.
You should have the ability to create the interval/workout that you need. All you have is Move, Rest. For running intervals, you may not want to rest at all but need an indicator that after e.g., 5mins at pace a warmup pace you now need to increase your speed for the next 30mins at race pace and then back down to 5mins for warmdown.
Coconutsyogi
Recovery Runner
This is the type of interval workout I need to program. I can't do this on the Fitbit. Sent via the Samsung Galaxy S20 5G, an AT&T 5G smartphone
lidamonstr
First Steps
Instead of only being able to set one interval for movement and one interval for rest, the interval workout could allow the setting of a whole workout program with many different intervals. For example, move for 1.5 minutes, rest for 1.5 minutes, move for 3 minutes, rest for 3 minutes, move for 2 minutes, etc.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @lidamonstr, thanks for explaining why you would like to have more options for interval workout. I've moved it into a similar request. I think that a lot of users would like to have this option on their Fitbit devices.You can learn more about how Fitbit decides what suggestions get released in our FAQs.
SunsetRunner
Not applicable
Definitely need unlimited intervals...the 49 is not useful for long distance running. Why has this not been updated by now? People have been posting about interval updates for several years.. come on Fitbit.
RonaMcQ
First Steps
Have recently upgraded to the Charge 5 and highly disappointed this still doesn't seem to be a thing – I have a pyramid workout to do (2/4/6/4/2 minutes of the workout, with a 2-minute active recovery between) but can't set more than the first 2 minutes on, 2 minutes off. The 'Add' button is there (implying I could add more), but inactive. Am I missing something, should I be able to add more?
LazyPlodder
Jogger
How has this not been done yet? I'd have stuck with Garmin if I'd known! Any ideas how long before this might be added?
Maki23
Jogger
I completely agree that this should be an option! Or at least be able to enter some favourite intervals so I can easily choose between those if I don't get a whole program of my choosing.
Ben_Fit
First Steps
Hello,
I totally agree.
This feature is a must have feature for a sports device.
Moreover we should be able to not be limited by the choice of the duration.
Having to add a third-party app for an interval timer can indeed be inconvenient.
Thank you
