Is there a way to add some way to manually add an exercise or workout that doesn't fit into the categories that are already in the manually entered exercises search. I use several different apps, programs that will tell me how many calories I burned based on how long I did exercises and to level of effort. Even if it was something as simple a second "other workout" and you can change the time and calories.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
