Save countdown time on Sense/Sense 2
The countdown timer on the Sense does not save once you exit the Timer app. For example, if I were to set a 30 second countdown timer, I want to come back to the Timer app later today or tomorrow and it would still be saved to 30 seconds. It does this on the Versa / Versa 2. It does not do this on the Sense.
Alta > Versa > Versa 2 > Sense
107 Comments
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @mattjrsmith, thanks for taking the time to share this suggestion about adding the option to change those default timers on Sense 2. I've moved it into a similar request. You can learn more about how Fitbit decides what suggestions get released in our FAQs. Click on the thumbs-up to show your support.
Thank you again for your participation in the Feature Suggestions Forums.
EmperorJJ1
Jogger
@mattjrsmith i wouldnt hold my breath on this one. might want to vote on it then look at some of the apps guy has released
azurelunatic
Jogger
I have a thing that should be checked hourly while I'm awake. If I keep the timer app open I can just re-use the previous time, but if I back out of the timer app to check the time or my steps, the timer doesn't recall the value I entered. It is also remarkably obnoxious to scroll back from 90 to get to 60. I suppose 45 would be worse, but a timer is not the place I would use that kind of number picker.
Also the survey that popped up to ask me how your website is doing is supremely obnoxious on mobile and did not open in a new tab.
tlandsperg
Jogger
The timer applet should have similar functionality as the alarms applet to allow the saving of multiple values.  Being able to quickly select a saved timer value provides the obvious convenience and saves time.
thatchrobot
Jogger
Yes it should, but it doesn’t!
Sent from my iPad
Zachnagy
First Steps
I use the timer function on my Sense2 two times a day every day (or more) when making coffee in a French press.
Please create a function that keeps the last timer set for the next use of the timer.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @Zachnagy, thanks for sharing this product feedback about saving the last timer used with us. Because this idea was already requested in this board, I’ve moved your post here. This will help us to make sure the product feedback shared here doesn't get confused, or split a popular vote. Please click on the thumbs-up to show your support.
