There is this great app called Sleep cycles! I’ve used this app for ever and it’s revolutionized the way I wake up in the morning. Here’s how it works: you set your alarm -say 6:30- and during the times 6:00-6:30 it will wake you up when you are at your most woke period during the 30 minute time period. It is wonderful for waking up naturally and I can’t live without it! If Fitbit could make the app compatible with the alarm and sync the sleep already gathered from previous cycles that would be awesome!!! If it doesn’t I won’t die I’ll just use the Sleep Cycle app and rely on the stats provided by Fitbit! But it would be so cool if we could sync up the stats and have the alarm wake up when the app wakes you up!
Moderator edit: Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
