I once loved using the app to check out my work out summary. Then there was an update that changed the summary format. It was awful, so I normally check it out through the actual website. Now, with another update, I can't even do that. Its the main feature I use but can no longer do that.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
