07-18-2019 11:56 - edited 07-22-2019 10:26
I am trying to create a Settings page for a custom watch face that uses an AdditiveList to allow the user to add an option to a list. The available options to add are also themselves a list, so I want to use a Selection element to give the user the list of items to select from to add to the AdditiveList. Something like this:
<Page>
<Section
title={
<Text bold align="center">
Settings
</Text>
<AdditiveList
title="SelectedItems"
settingsKey={"selectedItems"}
renderItem={item => {
if (item && item.name) {
return <Text>{item.name}</Text>
} else {
return null;
addAction={
<Select
label="Select a new item"
options={[
"name": "Option 2"
"name": "Option 2"
However, I find that using a Selection as the addAction in an AdditiveList causes the settings app to crash with "Settings: TypeError: Cannot read property 'name' of undefined". I simplified the app all the way down to as basic as possible, and the error still reproduces.
I have uploaded a stripped-down example to github. If you clone the repo and try it using the CLI or using fitbit studio, you'll see the issue reproduce when you open the settings app
https://github.com/dslane/ions-js/tree/master
Has anyone else seen this issue? Is this a known issue of the 3.1 SDK? Is there a known workaround?
08-02-2019 16:51
08-02-2019 16:51
Is there really nobody who can help with this? Nobody else has encountered this issue?
Best Answer06-02-2022 12:13 - edited 06-02-2022 13:19
In case this helps anyone else, I had this issue and solved it by running
settingsStorage.clear();
in my companion index.js - apparently, it had saved some settings from a previous AdditiveList definition I had written earlier, and was trying to re-load them, but failing because I had changed the markup. Of course, that call to clear the settings should be removed again afterwards otherwise it will keep forgetting the settings.
